‎2013-01-24
09:01 PM
‎2023-05-24
07:30 PM
Rubia Torres
‎2014-01-16 12:32 AM
‎2014-01-16 01:03 AM
‎2014-01-16 07:05 AM
‎2014-01-16 02:11 PM
‎2023-02-28 09:06 PM
Hi PB,
you can use free software "meshlab". There is option to import mesh (pointcloud) xyz etc. And reduce number of points by filters. You can for example set radius where should be closes point or set number if points in total. In the end it is possible save it again in xyz format. It is also good if you have more files and you need to merge them together. Cutting and planty of other options.
Good luck
