How can i open PNE
I would like to know how to open PNE format Archicad 6 [Edu] file in Archicad 10.
An error message is displayed in ARCHICAD 10 when i try to open a PNE file.
Can someone please solved my problems
5 Replies 5
Unfortunately this is not possible.
The whole idea behind the Educational versions is that Projects done in EDU version will not be opened in commercial versions. This is a limitation that was probably included in the material you received with the EDU version.
So, in short, it is not possible in any way.
Is it possible with ARCHICAD 10 Educational version ?
Djordje
Try with 10 EDU. 9 EDU should also work, if you can find the CD.
Be sure to find the 6.o library somewhere ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
stefan
ArchiCAD 10 EDU is not possible, since it is identical to ArchiCAD 10 but with a banner. The EDU version of 10 does NOT use a separate file format, like the old EDU versions.
It is best to try with ArchiCAD 9 EDU + the old library, if you have it available.
Archicad-user since 1998
my Archicad Book
Plus, Archicad 10 opens only files created with Archicad 6.5 or later.
