How do I create a Simple Parapet Facade?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-04-04 03:36 AM
‎2008-04-04
03:36 AM
Where can I find info on how to create a simple parapet facade on the front of a single storey unit?
Can I use my composite AAC veneer and timber frame wall to shoot the external AAC veneer part of the composite up? or do I need to create a separate wall on the next storey. I would like to be able to avoid a join line showing in 3d views. Or do I just have a simple timber frame wall on the front and put a separate AAC wall 20mm offset from the timber frame to avoid a join line?
What is the best and method for this?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-04-04 11:14 AM
‎2008-04-04
11:14 AM
There will be no join line if your walls join and the adjoining materials are the same. But I think you should experiment a little.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-04-04 01:44 PM
‎2008-04-04
01:44 PM
Thankyou for your time Thomas I will give it a try with a wall on the next level.
