General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
ArchiRADAR Responsive Facade Library with Grasshopper connection
Mario Sacco
If you are trigged with Grasshopper and Rhino, we propose the use of the Responsive Facade Library.
The library was conceived to speed up the designer's work in computational designs. The responsive panels can be managed directly in Grasshopper using the Archicad connection; you will be able to create complex design with panels and pipes, starting from Rhinoceros using a simple surface. A graphic interface of the object helps the designer in managing all the features. Using MVO Model View Option you will be able to manage the setting of the objects with only few clicks without selecting and editing every single object. You will be able to create also schedules grouping similar objects under the same column.
Test a models on sketchfab.
https://skfb.ly/pCRVz
Test the library here:
https://www.archiradar.it/en/3d-objects/objects-on-sale/product/view/47/927
Screenshot 2025-11-05 alle 07.42.15.jpgScreenshot 2025-11-02 alle 09.04.53.jpg
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
2 REPLIES 2
So freaking awesome man! This is some good work!
mikas
Impressive!
I went and paid the membership + for the definitions/objects. Going after the required Paneling Tools shortly too.
I have seen this before, but Thanks for reminding, I am a lot into grasshopper at the moment.
AC28, Rhino8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
