How do i intersect/join two roof parts?
Is it posible to fix the joint between two roof parts so its not vissible in the elevation view and also in the perspective view? (wnat it to look like one piece)
2 Replies 2
Trimming the edge of each roof to the other with set the correct angle to the edge of the roof.
But seeing as you already have the ridge in the correct location selct the edge of the ridge and in the pet palette choose the custom angle option (last tool top-right of the pet palette).
Set the edge to be vertical and this should solve your problem.
David Maudlin
If you are using a later version of ArchiCAD, this type of roof is modeled better with a single Multi-plane roof than 2 Single-plane roofs.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
