How do i make a wall vent
I want to create a brick 'wall vent', the issues i have so far are;
1) I have made it out of a custom profile wall and it wont save as a window component,
2) Then i tried it as a library object but if i were to do it this way, I think I need to put an empty opening into the wall with a blank window and then stick the library part in the wall gap. This opening is visible in plan which is what i do not want.
Pls Help
2 REPLIES 2
Steve Jepson
What version of ArchiCAD are you using?
Dwight
Consider saving the object as a window.
Or, adding the GDL script WALLHOLE ( or something like it) to cut the hole for you.
Dwight Atkinson
