How do i set, to insert and rotate objects in one sequence.
Hi I'm Relatively new to archicad, When I insert an object, I have to insert, it then using the seperate rotate function, rotate it
this is in two seperate moves.. sometimes three if i stuff it.
I can't find where to alter my settings so that when i insert an object it will automatically ask for rotation straight after I click on where i want it... Help.... It will be so much quicker.
1 Reply 1
Cancel my last Question.... I'm an idiot... Should have done the beginners course.
