Thank you for the reply David!
Here's what I've cooked up. As you can see, there's a huge hole in roof
![](/legacyfs/online/emojis/icon_razz.gif)
How do I go about closing this hole?
I think it would be better if it is closed a few cm back.
Then I don't have to create the fascia boards I was talking about earlier, as they allready form part of the other roof parts.
Also...
I created each roof part (the different slopes) using the polygonal roof tool. That was very time consuming, and irrated me quite a bit. I then tried the PolyRoof one which worked great! But I could not select individual roof parts, it selected all of them the whole time.
How do I select individual roof "slabs"(If I can call it that?) Is there a way to "explode" them (sketchup talk
) so you can select them individually?
Thank you once again in advance!
Kind Regards
Renier
