arg617
How do you show building outline only?
Hello. I'm trying to create a site plan and can't seem to figure out how to show the outline of the building only. Any help would be appreciated. Thank you!
If you want to show the actual external walls only then it is just a matter of layer control.
Make sure the wall are in a layer that can be turned on for your site plan and turn off all other wall layers.
If you just want a single line for your building perimeter then I would magic wand or draw an empty fill around the external of the building and then make sure that is in a layer that you can see on the site plan.
The advantage of a fill is you also can then determine the area of you building/s and can even schedule them.
I use fills with different IDs for all the different building areas (main building, garage, workshop, courtyard, etc.) that I can then list in a schedule for the areas.
arg617
Thank you Barry! The fill is what I used.
