How to Draw This Kind of Wall?
Hi there
I am working on archicad for 4,5 months, and I faced a problem today, and found your forum.
I would really appreciate you, if you help me to draw this kind of wall.
I attached the shape of wall here.
please answer me as soon as you can, because I have a presantation the day after tomorrow.
Your care is highly appriciated.
Thnx
30 Replies 30
Dwight
Thank you Ignacio.
Correct assumption - why fix bad design with a parody?
That drop-a-letter compression is also an homage to Object/Element dialog boxes that by default are too small to contain their text contents and you make an entire book with the too-small dialog boxes in it and feel like a total fool once Eric Bobrow diplomatically shows you how to close the folder window AND THEN stretch the dialog without using the phrase "you moron." Sort of like my brother-in-law at his farm when I showed him how to use a razor knife to cut styrofoam insulation instead of a handsaw like he had been doing for 1200 sq ft worth. Little bits of white stuck all over him from friction static. Duh. Hahahaha. I never said it, either.
Dwight Atkinson
