How to Unhide the roof again?
Hi
I accidently hide the roof object
now cant see it in 3d view...how can I unhide it back?
3 Replies 3
Stephen Dolbee
Is it on a layer that is turned off? If so, hit Command/L and turn it back on.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
pilgonico wrote:
Hi
or using "Quick Layer" Palette to undo your layer state ! (press Window/Palette/Quick Layer)
If you've never use this function before, you maybe need to have a quick look on the manual.
HTH
Or did you filter it out of you 3D views?
This is regardless of what layers are on or off.
