How to avoid wall thickness getting dimensioned
I'm dimensioning from the outside corner of two walls to a window in this case. Using Core Only setting for the dim tool. I get a dimension of the wall thickness and one from the inside of the wall to the window.
How do I get just one dimension from the outside corner to the window?
Thank you for any clues!
Rod Jurich
See attached Doug, or delete the inner wall dimension.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
vfrontiers
To emphasize Rod's tip...
Make sure your cursor shows a CHECK MARK when clicking on the wall and NOT a "mercedes" (surface click)...
By clicking on a surface while dimensioning, you are telling AC to dimension both sides.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Rod Jurich
Rod Jurich
