Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
How to change direction of a polyline?
How to reverse the orientation of a line or polyline?
In AutoCAD, there is RvrsLine utility. What is the solution in ArchiCAD (15) ? For me it's a big problem.
Thanks for the solution.
David Maudlin
Miky9:
For a Line, mirror the Line on its center point.
For a Polyline, I had some success adding a Line to the end of the PolyLine, then using the Magic Wand on these 2 parts to create a new Polyline that is the opposite direction, then stretching the extra segment of the new Polyline back to its original end to eliminate it.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
rocorona
One can have several needs, that seems addressed by some software. I know ArchiCAD has more than 500 commands, and AutoCAD a lot more. Anyway I doubt there is one to choose to "reverse" the linetype horizontally or vertically. Sometime it can matter.
I'd keep it simple, and duplicate the linetype, with reversed elements.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
