How to clear recent file list?
Clear the recently used listing under File>Open?
7 REPLIES 7
You can very carefully edit the preference file (Mac) or registry (Windows) for your AC version under the key Recent Documents.
There are additional keys called RecentObjects and RecentPlans that give an integer number for the max number of GDL objects and projects that will be in the recent list. I have not tried this - so do at your own risk - but conceivably, with AC shut down, if you change these values from the default '12' to '1' and start AC, it might automatically purge all but the most recent items. You could then exit and reset those values to the desired max.
One of the forum moderators
Thanks so much for this tip.
I've needed to clear the recent template location and recent files to clear old server paths as ARCHICAD 19 kept connecting to it when opening ARCHICAD.
I just came by this thread by accident and as it turned out, since ARCHICAD 16 this info is no longer stored in the Preferences/Registry.
There is now a file which stores this information and to clear the Recent Files list you can simply delete the File.
On Windows, for ARCHICAD 20 INT, it is stored in the following folder:
C:\Users\<USER>\AppData\Roaming\Graphisoft\ARCHICAD-64 20.0.0 INT R1\
Simply quit ARCHICAD, then delete the "Recent Documents (Project).prf" file in this folder and when you restart ARCHICAD the recent file list will be empty.
I suppose on Mac you need to do something similar.
I don't have a Mac so hopefully someone can verify this.
ChrisB
Very useful to know, thanks for the update.
I can confirm that this also seems to be the case on the Mac, although different location. For an installation of Solo, this file can be found in...
/Users/<UserName>/Library/Preferences/Graphisoft/AC-64 20.0.0 UKI v1 SOLO/x86
AC16-28 Solo (latest version)
OSX 15.2 - MacBook Pro 16" 2.4 GHz 8-Core Intel Core i9 - 64Gb DDR4 - AMD Radeon Pro 5500M 8 GB
Thanks Chris,
Also, it may be important to note that the "Recent Documents (Symbols).prf" file in the same folder contains the list of recently opened GDL Objects, so deleting that file will clear the list of recent GDL object files in ARCHICAD.
Thanks for the update, great to know.
laszlonagy wrote:
Thanks Chris,
Quite the same in the Mac. Begin by accessing the Library/Preferences folder holding down the option key while using the Finder "Go To Folder" command. Enter ~/Library/Preferences. You can also refer to the following link: https://discussions.apple.com/thread/5056256?start=0&tstart=0
