How to connect a wall to a rotated-column
Howdy fellas,
Okay, Here's my next problem...connecting stud partition wall to a C section Column that does not sit 90 degrees to the wall. Take a look at the piccy please.
Thanks
1 REPLY 1
You could use the old trick of placing a zero thickness wall at the face of the column and intersect the wall with that. It's a bit of a workaround, but is easier than trying to get the wall end tool to do it.
