‎2005-06-1003:38 PM - last edited on ‎2023-05-2612:53 PM by Rubia Torres
‎2005-06-1003:38 PM
Howdy fellas,
Okay, Here's my next problem...connecting stud partition wall to a C section Column that does not sit 90 degrees to the wall. Take a look at the piccy please.
You could use the old trick of placing a zero thickness wall at the face of the column and intersect the wall with that. It's a bit of a workaround, but is easier than trying to get the wall end tool to do it.
