How to connect curved Wall to straight Wall?
i'm new quite new with ArchiCAD and have a connection problem you can see as attachment.
I have a curved wall that should connect with a straight wall? Have tried several reference line-combinations, but none seems to work?
Can anyone help me, please?
Thanks!
12 Replies 12
Can someone explain how to do the 'fudge' mentioned here? It sounds like it answers my previous post about 'patches' ?
Thank You
David Maudlin
debjayne:
Just use a Fill that matches the fill of the walls and draw it to cover the line(s). You may need to use the Display Order (Bring Forward, Move Backward) to get the fill to cover the walls. This is a 2D solution, it has no effect on the 3D model. The Patch solution is more complex, involving the creation of a custom library part to do this job, but the Patch can more easily be reused for multiple identical instances.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for your help
