‎2020-07-09 07:32 AM
‎2020-07-09 04:09 PM
avishiplu wrote:Can you explain"using line weight" about shadows ?
When I send Cad file with shadow they asked me to send the drawing just using line weight.
‎2020-07-09 05:49 PM
‎2020-07-09 06:49 PM
‎2020-07-09 06:57 PM
Christophe wrote:Dear Christophe
Hello avishiplu,
avishiplu wrote:Can you explain"using line weight" about shadows?
‎2020-07-09 08:05 PM
‎2020-07-09 08:16 PM
‎2020-07-10 03:34 AM
‎2020-07-10 12:50 PM
‎2020-07-10 04:11 PM
Barry wrote:Dear Barry Kelly
The only option we have is the "Marked Distance" option that will give you 2 different line weights.
But that is it.
To get any more than 2 line weights you will have to manually add lines or maybe you can set up multiple elevations and limit the depth of each one.
So where the extent of the first elevation stops the second elevation starts.
Where the second extent stops, the third starts, and so on.
Then you can override the line thickness in each elevation.
Now you just have to stack all of the elevation drawings on top of each other in the layout.
It should work but I think it is a bit messy.
