artktecture
Opening Tool - issues at wall outside corner
I have 2" stucco walls that I'm trying to use the opening tool to wrap a 1" reveal around the corner in the stucco. I'm having issues where the openings do not cut out all of the wall. No matter how I set the wall reference line or opening settings there are 2 little bits of stucco left at the corner. Any ideas?
artKtecture uses Archicad 24/Twinmotion
Lenovo Thinkpad | Xeon [email protected] GHz | 32GB | Quadro P4200 8GB
Oculus Rift S VR tours
Contour Rollermouse Red Plus (ditch your mouse and get one of these!)
Using a highly modified Shoegnome template (Thanks Shoegnome!)
Lingwisyer
Guru
Each Opening is linked to both walls? And since your wall is a composite, if the reference line is on structure, do the Openings extend to the external face?
Ling.
artktecture
Thanks, I did not have the openings cutting both walls. That creates the proper reveal however I end up with some unwanted visible lines that I can not seem to get rid of.
I created the stucco reveal on the bottom with the wall niche tool and it seems to work much easier than the wall opening tool with no unwanted visible lines. It's much easier to constrain and drag for length.
