muzedesigns
How to create an object that repeats and doesn't stretch..?
Hello!
I am trying to created trim deck Metal sheeting to run around the perimeter of a building - like a typical factory finish..
I am using the Profile editor.. but is there a way to make it a library object so it acts/has the properties of a fence type object, so the at repeats sections without stretching the object.. any advice or suggestions or help would be greatly appreciated..
I have attached a image showing the profile as it is now (a column) and the 3D view..
Thanks!!
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
David Maudlin
Chrissy:
Your attachment/image did not go through.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Maybe you could try to achieve the same using the Wall Accessory.
