How to create this Wall ?
Hi all,
I wonder how to create this wall? Using complex profile or a simple wall tool or something else?
Please advise.
Many thanks
p.s. This wall is the the side wall of a disable ramp.
17 Replies 17
put your wall in with the height of the highest point. then place a roof surface over it at the cut angle you want and then trim to roof (under design)
That's one way.Many thanks
Do you know other alternatives? More simple like in sketchup that we can just drag points/hot-spot or something ?
thanks
Dennis Lee
You could draw that wall's elevation view in Complex Profiles, and draw the wall in the short direction.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Fran_ois Chatelain
Hi Tran,
if you don't need openings in it, simply use the mesh tool with sharp edges.
Cheers
Francois
François Chatelain
Worldwide Digital Imaging
Formerly posting as RanXerox
"A little bump will help blur your reflections"
It does not need any opening. thanks
Hi all,
Many thanks for your inputs. All are great help. They all work.
Link
Well that's ironic, because you could actually use an opening (with an inclined sill) to cut that shape out of the wall.
Link.
When i do that it wont show the wall if i cut a section thru it.
Dennis Lee
I had to try it to see, but as you can see, it does show no matter which way you cut the section. The wall is drawn in the short direction as I was saying.
Windows 10 x64
Since ArchiCAD 9
