‎2008-12-03 07:37 AM
‎2008-12-04 09:13 PM
‎2008-12-05 10:12 AM
s2art wrote:There is no need for SEO here. Place a cutting roof plane, Trim to roof. It holds, whatever you do with the roof later.
Use a roof (the "operator", on a layer which you can turn off) to SEO* "subtract with upwards extrusion" from the wall (the "target"). If you ever have to modify the cut line just move the roof as required and the resulting cut will change automatically (just don't delete the roof).
*Solid Element Operation, under Design menu.
‎2008-12-06 05:28 PM
Djordje wrote:Unless you need to extract some documentation from the model (and not just pretty pictures). Then you have to use a wall, and SEO or cut-to-roof.
The mesh solution is probably the least painful one.
‎2008-12-07 12:56 AM
‎2008-12-07 01:00 AM
‎2008-12-07 02:58 AM
‎2008-12-07 03:03 AM
‎2008-12-07 09:11 AM
Bier wrote:You can easily do that cutting the wall with a roof then inserting a inclined beam made with a complex profile.
Ok, so the answer is no for now.
