How to edit a detail marked
How to edit a detail marker once is placed in the drawing, or do I need to delete the one thet need editing and make a new one?
Thanks.
7 Replies 7
Erika Epstein
What kind of edit are you attempting?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I wanted to edit a detail marker that it was already created, but I think is better if I delete it and start again, or do you have any sugestion?
thanks!
Erika Epstein
It is difficult to answer your question when you do tell us what specifically you trying to do?
Are you trying to change its size? move it? link to another detail?
Also include in your profile platform & version of Archicad you are using.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Change the ID and name,
thanks!
Erika Epstein
Hi Mario,
It sounds like you are trying to edit a linked marker as these items would be grayed out in this situation. You have a couple of options.
1. Right click on the selected detail and choose "SET AS SOURCE MARKER". This will allow you to make those changes. When done, right-clicking again on this same marker will allow you to turn it back into a linked marker by choosing 'SET AS LINKED MARKER'.
2. If you want to find the source marker, right click on the detail in your view map select 'FIND LINKED MARKERS' click on the first one listed, right click and click on the GO TO SELECTED' button. This will take you right there. Select it and then you can edit the ID and NAME.
3. To be tidy, you can right click on the detail in the Project Map and rename it to match.
HTH
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Hi Erika,
Thanks a lot, I got it fixed!!
Link
In AC12, can you just skip straight to step 3?
Link.
