lagodue
How to get 4 section/elev markers in the center of a space?
In order to optimize what I see in my section/elevations, I need to place the sec/elev in a specific location in a space. Rarely will this be in the center of a space for more than one marker. The result is 4 markers in different places in a room.
Can I adjust these marker locations without changing what I get from them?
"Bob" - Church of the Sub-Genius
Graphisoft afficionado since 1993
1 Reply 1
Yes (unless i've completley misunderstood the question):
-Select the section line and go to the section/elevation settings (Ctrl + T)
-In the section/elevation selection settings window, go to the 'Floor Plan' section and where it says 'Markers' select 'Elevation' rather than the default of 'Section'.
-Back in the floor plan, click on the hotspot that is attached to the marker and you can move it around to where ever you like. The section will be taken from the line rather than the marker.
Tom
