lagodue wrote:
Can I adjust these marker locations without changing what I get from them?
Yes (unless i've completley misunderstood the question):
-Select the section line and go to the section/elevation settings (Ctrl + T)
-In the section/elevation selection settings window, go to the 'Floor Plan' section and where it says 'Markers' select 'Elevation' rather than the default of 'Section'.
-Back in the floor plan, click on the hotspot that is attached to the marker and you can move it around to where ever you like. The section will be taken from the line rather than the marker.
Tom
