ELEVATE
Dimension Text Placement
When I have dimension text placement set:  Main dimension (text)  is center &  and short dimension (text) is set to below dimension string.  But when I create new dimension string it does not position the short dim line under the dimension string ~ it puts in on top of string.  I would like it automatically located under the dim. string.  What am I missing?    Dimension is a continuous line.   Thanks for your help.
Operating system used: Windows 23H2
DMD
David Maudlin
ELEVATE:
That setting seems to apply to only interior dimensions on the string, not at the ends.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
@ELEVATE,
Besides choosing the "Flexible" Dimension Text Placement Method, is the "Allow below Dimension Line" option also enabled? From your screenshot, it seems like it is not enabled. It is the button to the right of the Placement Method button in the Info Box.
