Dimension Text Placement
ELEVATE
When I have dimension text placement set:  Main dimension (text)  is center &  and short dimension (text) is set to below dimension string.  But when I create new dimension string it does not position the short dim line under the dimension string ~ it puts in on top of string.  I would like it automatically located under the dim. string.  What am I missing?    Dimension is a continuous line.   Thanks for your help.
Operating system used: Windows 23H2
DMD
David Maudlin
ELEVATE:
That setting seems to apply to only interior dimensions on the string, not at the ends.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
@ELEVATE,
Besides choosing the "Flexible" Dimension Text Placement Method, is the "Allow below Dimension Line" option also enabled? From your screenshot, it seems like it is not enabled. It is the button to the right of the Placement Method button in the Info Box.
Setup info provided by author
