How to get wall and door dimensions
Hello, i'm working in Archicad 14.
I want to know how to get wall and door dimensions.
And in archicad 9 i have 2d north view, east view, south view, west view.
But in Archicad 14 i can't find them anywhere. Please tell me where are they.
Thanks for your help a lot.
3 Replies 3
Hi Martin,
If you select a door or a wall, you can find those dimensions in the Info Box (or simply hit CTRL+T to see their settings). You can also use the Dimension or Measure tool (or even a simple line, while watching the distance shown in the tracker or in the Coordinates Palette).
Hope that helps,
Adrian Tudoreanu
Thanks, Adrian. Now just searching for the views.
For that, you can use the Elevation tool (you can access it from the toolbox palette or via Document > Documenting Tools > Elevation).
Adrian Tudoreanu
