2023-02-26 09:20 PM - edited 2023-03-03 09:27 AM
Hi, I'm following a tutorial on grouping, which is quite simple. Select multiple objects > ctrl+g. Then you should be able to select all objects in the group by selecting one of them. But for some reason grouping objects does not do this. The objects change color slightly but when I deselect them and try to select one, only one is selected, an not the group. Is there a reason for this? How do I fix it?
Solved! Go to Solution.
2024-04-18 11:49 PM
edit > grouping > suspend groups
