How to load 5th facade?
How can i properly load 5th facade view?
12 Replies 12
The setting of Floor Plan Cut Plane is saved with Views.
So I would suggest that you save Views for those Stories with different Floor Plan Cut Plane heights, and move from one Story by restoring those Views.
Daut wrote:
Thank you for the answer, can i change height of floor plan cut for just one floorplan or it automaticly applies to all floor plans?
It is saved separately with each view of the floor plan.
So you can create multiple views of each plan and they can all have different Floor Plan Cut Plane heights as well as other settings (scale, pen set, graphic override, etc.).
Woops, I didn't jump to the next page so didn't see Laszlo's reply.
Thank you!
