Llian
How to remove limits from Interior Marker
I don't remember seeing this in previous drawings but now there is grid around the interior marker. I see it's is the limits of the interior views but how do I remove the grid from the interior Marker?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 Reply 1
Only the marker will print.
The elevation limit lines (the outer ones) and the actual elevation line (the inner ones) will not print.
If you really want to you can turn them off with "Marker Range" in the On-screen View Options.
The elevation limit lines will be dotted if set to 'infinite' in the settings and will be a solid line if set to 'limited'.
The infinite (dotted) limit lines should be stretched to encompass your room.
The limited (solid) extents can be stretched separately if limited is turned on.
