How to select single wall instead of chain of walls?
Hi everyone, i want to select one wall instead of the default selection of the programme of four walls.
2 Replies 2
Suspend Groups
Do you mean the geometry method? There is a popup in the info palette that lets you draw walls as single, continuous/chained, rectangular, etc. you can also cycle through these with the "G" key by default.
