‎2021-06-16 04:41 PM
Solved! Go to Solution.
‎2021-06-18 06:57 PM
kosta wrote:Perhaps because Custom Closure uses just the Wall Skins pens and fills.
Why custom closure option don't have WALL CLOSURE tab inside "floor plan and section" dropdown?
kosta wrote:Yes. Windows/Doors Wall Closure and Reveal sometimes can be very enigmatic. That's why I suggest you to create your favorites and forget about it.
Thing is custom closure lefts that bold stick in wall too, but with custom closure you can't access to that tab and change pen, that is interesting ...
‎2021-06-16 06:08 PM
‎2021-06-17 07:25 AM
‎2021-06-17 08:39 AM
‎2021-06-17 11:36 AM
‎2021-06-17 01:21 PM
kosta wrote:Check your contour pen for your wall closure on your Door settings.
First issue is that bold stick penetrating wall on the right and left side of the door, can't get rid of it...
kosta wrote:The lines you are referring, are the wall contour lines, that are also set on your window settings.
One other moment are those windows and doors, they are same line weights as you can see, how can I set them so to make only cut lines bold and bottom is thin.
‎2021-06-17 04:53 PM
‎2021-06-18 01:34 PM
Braza wrote:Braza I'm sorry when I said yesterday that it is ok, I was counting that I will find that WALL CLOSURE tab and Contour Pen properties. In your case it sits between Override MVO and MASONRY ARCH, but I'm not able to spot that menu at all. Your screenshot:
Then after you define the correct line weights for your door and window, save them as Favorites. So the next time you have to use them the work is already done.
‎2021-06-18 05:56 PM
kosta wrote:No problem.
‎2021-06-18 06:22 PM
Braza wrote:Thanks and that's right, with traditional closure I can see WALL CLOSURE tab and I can disable strip at all.
Braza I'm sorry when I said yesterday that it is ok, I was counting that I will find that WALL CLOSURE tab and Contour Pen properties. In your case it sits between Override MVO and MASONRY ARCH, but I'm not able to spot that menu at all. Your screenshot:![]()
The reason this drop down is available is because I used an insulation strip with the "Traditional Cavity Closure" in the Window Cavity Closure Option. If you don't need it uncheck it, and the line will disappear.
Hope this helps.
