How to show building as outline in 3D MODE
Working on a site with three buildings. Only one is being modified. Is it possible in 3d to show the other two buildings as sillouettes? Onlhy want the building in question to show.
matthewjj
You could do this a number of ways. Since you have 15 you could use the renovation settings to create a different 3d material for the existing/new objects. You could also just change the materials for those buildings you don't want to emphasize with white, great, glass or ice. I'm sure other people will post some good ideas.
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
My fix: I saved all 3d and elevations as jpg, then using the fill tool with a .7 black outline, drew around all I did not want to see, grouped the picture and voila!!! it is done.
That renovation tool is a mess as far as I am concerned, makes me have to make too many decisions on every tool, every step and just don't use it at all. I am an expert in layers and able to work faster this way.
