Professor Pickle
How to show swing for curtain wall door panel?
I'm really struggling with this. I'm working in AC23 and I've got a curtain wall with one of the panels set to "CW Door 23"". I am unable to make it show door swing in plan view. It always gets displayed as closed. Is there some special trick to this? Some help would be much appreciated.
Pushing the boundaries of local time/space continuum since 1972.
Archicad 26 | iMac (Retina 5K, 27-inch, 2017) | 4.2 GHz Quad-Core Intel Core i7 | 24 GB | Radeon Pro 580 8 GB | macOS 12.6
1 Solution
This should be what you are looking for.
Go to post
3 Replies 3
David Maudlin
Tomek:
In addition to Barry's advise, set Curtain Wall System > Floor Plan and Section > Floor Plan Display > Projection Mode > Cut Components > Symbolic.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Professor Pickle
Thanks for that. Turns out that I had my cut plane in the wrong place. I was manipulating it for this one view and then I forgot that I had made that change. It's a bit odd thought that this would have such an effect since the door in question is a floor to ceiling door. Still, at least now I know what to expect. Thank you all for your help.
