How to store a new Complex Profile ?
Is there a way to store a nem custom made profile to use in other projects and machines without opening the project where it was created?
I couldn't find a way to do it, neither a folder that the profiles are...
4 REPLIES 4
Put it in your favorites.........as the wall or column or whatever you're using it as.
Complex profiles are attributes so in the project you want to
use a profile that exists in another project simply open
attribute manager and open the attributes for the other project
and add the profile to the project that is open.
Peter Devlin
as above. there usually done for that particular project.. if u want it to be used in multipul projects you should stick it in your master template
Thanks a lot everybody
I don't know how to use the templates well. But I will try 😃
