How would you draw this in ArchiCAD?
I need to draw this model I have made for a project at University. So far I have only drawn a 3D house in ArchiCAD, but that was made up from walls etc. What I want is a basic frame to show the shape and intersection of my model. Which tools etc, would I use to get it 3D
82 REPLIES 82
Erich
They offered the AC11 version for free but then started the small charge with the advent of AC12 if I recall correctly.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Dwight
For €30, I'd be learning code.
Dwight Atkinson
could you just refresh my memory on applying a roof ? I have the walls, but when I use the roof tool it always goes below the walls and ' into the ground'. I've changed the ' height from' but it doesn't work.
Sorry for my lack of knowledge, and I wold prefer to get a a straight answer on here than the manual.
Thanks
Thanks
How do I use the object, once I've added those lines to the scrips? I only have the preview box and I can't actually use it...
Thanks
upload your object, than we can see what you have got.
(note: zip it first)
Well this is all I have managed to do so far... And my Tutor keeps saying to use Sketchup, but that's not what I want to do.
Just download this free object rotator from the object deposit, it may be just what u need right now:
http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/Archicad%20Modules
It´s free and there is no add on - works really well.
Thanks ! How do I open my object with that open ? Sorry for my non-exsistend understanding.
Load the Rotator.gsm object into your library, then in the parameters field you fill in the "Name of library part to rotate" parameter with the library part name u need to rotate - in your case it would be "Shelter 2" according to the object you uploaded. Copy as many instances you need and change the rotate parameters as you need.
