HowTo create door/window any element at exact distance from wall or another element while creation?
Hi!
I can't manage how to insert object into walls so to make it lets say 1000units sharp from opening that is on left side ..
I hope I dont have to randomly insert elements there and only after tweak distances ...
1 Solution
Jp1138
I think this tutorial could be useful:
ARCHICAD 29 SPA (as long as the server works)
Windows 10
Go to post
3 Replies 3
Jp1138
Windows 10
Thanks , it helps , but still think it's complicated a little bit, in revit that is solved more easily by having 2 interactive dimentions at left and right side of element .
Dontknow
Make sure you align your window to the right side and hold your mouse on the edge of the other window (without pressing any mouse button).
Then press X for horizontal and Y for vertical distance, followed by the offset distance with a + or - (500+) and press enter to place the window.
Made a video of it.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
