IMPORT ac9 fill into ac10 fill library...
HI
well it's very simple, the topic says all 'cause when i saw the fill library in ac10, there are some missing fills that were in ac9 (why?) so i want to know if there's a safe way to import those fills.
thxs
Link
Use Attribute Manager in AC10. Open the AC9 file in the right pane and Append the attributes you need to the current AC10 project. I would strongly suggest not using the Overwrite button.
Link.
