INSERT ROADS ON THE SITE
I saw a tutorial about inserting a slab as a road on a site mesh with the SEO using the Subtraction upward.
It was amazing.. but my site mesh is very irregular, and the slab is a plane.
I`m tring to edit the nodes... is there another way to do this? and how can I weld the nodes of many slab to make only one???
Thanks
5 REPLIES 5
I`m trying to insert the road on the irregular site.
I found a tutorial but it was using a slab. In my case, the roads aren`t straight and plane. They follow the terrain mesh.
What is the best way to do it without architerra??
Thanks a lot
Erika Epstein
1. Set a slab the plan shape of the road.
2. Using SEO set the slab road as the Target and the site as the operator. The operation set to INTERSECT. This will trim the slab to be just where it intersects the mesh and the top will mimic the mesh irregularities.
3. Now using SEO set the mesh as the target and the road/slab as the operator and subtract with upwards extrusion.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Sorry... I try that Erika, but all I get it is this image below...
What I am i doing wrong\\??
Thanks a lot
OHHHHH now I understand/... is the thickness of the slab that shoul be higher that the site mesh....
THANKS A LOT Erika...
I was desperate to do that
Srinivas
You can find some help here as well.
http://archicad-talk.graphisoft.com/viewtopic.php?t=9973&highlight=mesh
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
