IS IT POSSIBLE TO DELETE A NODE FROM A MESH ?????!!!!
HI ALL - Great weather here in Sunny Jersey !! Does anybody no if it possible to delete a node from a a mesh ? Or delete a number of them at once some how ??
Thanks
Myles
5 Replies 5
move the one you want to delete over an existing one and i believe it will dissapear.
thanks but that don't either
Myles
David Maudlin
myles:
A mesh point can be deleted by dragging it beyond the perimeter of the mesh. Multiple points can be deleted by creating a hole surrounding the points, then deleting the hole.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Sometimes when the Mesh has been worked on a bit, there may be mesh points that are actually several points. So you drag the point to another to make them one point and it looks like the moved point remained. But the case is that there were several points at the same location. So you just have to repeat the move until all points are deleted.
Thanks everybody for your help - the dragging off the node tip from the mesh is the one we needed
Thanks again
Happy cadding
Myles ( xmas is on the way kids )
