Tom Krowka
Import a Word document
I am trying to import a word .doc into AC. Apparently, the only way to do this is through cut and paste. However, I can only get the first page of a two page document. I tried going back to the word doc., and cleared the clipboard, then copied the second page. Upon pasting into AC, I get the first page.
I also tried it in Plotmaker, under file/import. I still can only get one page.
I resaved the word .doc in a txt. format, still only the first page.
Any suggestions?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 Replies 2
Tom wrote:
...I can only get the first page of a two page document.
That is correct. You can only import the first page of Word documents in Plotmaker (or ArchiCAD).
Any suggestions?
Try out this link: http://www.graphisoft.com/support/archicad/archiguide/olefromword.html, this discussion: http://archicad-talk.graphisoft.com/viewtopic.php?p=9931&highlight=import+word#9931, and other discussions as they arrise.
Tom Krowka
Thanks for the heads up. I will update you if I come across anything better.
I wonder which program has the limitation, word or AC.
Thomas@wkarchwk.com
www.walshkrowka.com
