ā2005-03-29 12:17 PM
ā2005-03-29 12:25 PM
ā2005-10-28 08:06 PM
ā2005-10-29 01:08 AM
mikeadams wrote:yes you are. as i said above, the 3DS in doesn't get loaded by default, so if you want to import '3D studio' files just follow those instructions. (archiCAD 9 only!)
I do not have the option to import 3DS files only output. When I go the Extras menu its not in there. When I go to the add-on manager the one at the top called 3D Studio Out is checked. Am I missing something.
I have been trying to get a 3D .dwg file to open as a library part so I can see it in 3d. This file was originally from sketchup and I want to take the sketchup file into archicad to do working drawings. There has to be an easy way to bring in the sketchup file to scale so I can model it in ArchiCAD. What a pain, I am so frustrated.you're using 'File>GDL Objects>Open Object...' and then selecting the DWG file right? if there is no 3D content in the resulting 'object' i would suggest either playing with the translator settings or checking the sketchUp! export process. (or, something i discovered recently: use the DWG in/out engine in archiCAD 8.1 - it seems far better than the 'developed' engine in archiCAD 9!)
ā2005-10-29 02:27 AM
~/archiben wrote:it looks like they've 'already' released it . . . in two days time!
you could also contact graphisoft with a view to "beta testing" their new sketchUp! inporter add-on. it was announced some time ago, but when i last saw it, it was still in pretty poor shape . . . i haven't bothered since because i don't believe there is any way of translating simple surface information into intelligent BIM information in a way that can cover all users needs.
ā2005-10-29 03:33 AM
ā2005-10-29 02:05 PM
ā2005-10-30 12:52 AM
tigr wrote:as far as i know - only 3ds files . . .
Ben, correct me if I'm wrong, but does the 3ds Import plug-in work only with the *.3ds files and not *.max files? Or am I missing something. Greetings
