Importing Master Layouts
When ever our master title sheets change, which is often, cause my boss changed his firm name, and is picky about how things look, I go change all the title sheets in one project, and then I have to copy and paste them into EVERY other project....
Our "Template" is just an ArchiCAD Solo Project taht we open and do a save as with.
So-
Is there a way I can Import Master Title Blocks, instead of copying and pasting them?
And is there a way so that if I change the title sheets in my template they will universally change in all projects using that template. And is that the advantage to using and Actual Template, as opposed to renaming a blank Project and using that as the template?
11 Replies 11
Da3dalus wrote:
Karl, you rock!
Thanks for making my day, Chuck. 😉 But, I confess that I learned this from Djordje:
http://archicad-talk.graphisoft.com/viewtopic.php?p=61819#61819
So: Djordje, you rock! 🙂
Karl
Djordje
Karl wrote:
Da3dalus wrote:
Karl, you rock!
Karl
Come on ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
