Importing PDF with background transparency
m_ziolo_86
I am trying to import PDF with background transparency. In general pdf files don't have background colour, it is only added by viewing program for better look.
However, when I am importing PDF to Archicad, AC imports the file with background filled and the option of background transparency is unavailable. Is there any way to overcome this problem ?
Regards
Archicad 16, Win 8.1
Yes - use the Figure Tool instead of the Drawing Tool:
http://www.archicadwiki.com/DifferenceBetweenDrawingAndFigureTools
The Figure Tool can only place PDF files directly on Mac OS X. For Windows, you'll have to convert the PDF to a graphics image format (PNG, etc) first. If you use Photoshop, the pixel density chosen during the opening/conversion of the PDF will significantly impact the quality of the placed image.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
m_ziolo_86
Thanks for reply,
But I am not interested in converting PDF into raster file. I want to have it in Archicad as a vector graphic with transparency.
Then you're out of luck unless you buy a Mac. You can make a wish - which may never be granted, or just convert it and move on with your work...
