‎2011-02-20 06:55 PM
‎2011-05-06 03:05 PM
Thomas wrote:The Figure Tool can do both of these. Karl posted a good comparison of the Figure and Drawing Tools here:
If you need to change it's proportions (that's often needed if it is originally scanned) you will have to convert the PDF to JPG or TIFF.
I should add that to make a PDF transparent, which I sometimes need, the only way I've found is to convert it to TIFF (if it's a bit-mapped image) or DWG (if it's a digital vectorial line drawing originally).
‎2011-05-06 05:22 PM
David wrote:Thanks David, I almost forgot this. Karl's comparison is quite comprehensive. Of course, if I drag-in a TIFF it's automatically regarded as a Figure by Archicad, that's why I can change its background transparency.
Difference between Drawing and Figure Tools
David
‎2011-05-06 05:43 PM
