In plan, change the linetype of another storey's slab {Done}
I have a slab assigned to my "subfloor" storey. I set it to show on other storeys, and set the UNCUT LINETYPE to "dashed".
However, in other storey plan viewpoints, the slab always shows a solid outline.
Inconsistently, however, I can set the UNCUT PEN to a particular colour, and that colour shows in all storey plan viewpoints.
And even if I set the slab to the height of all storeys, so it's definitely should at least be "cut" - and show the "cut" linetype - it always just shows as solid, regardless.
Is this just another "feature" of AC, or am I missing something?
Brett Brown
Have a look at Options-Project Preferences-Construction Elements. This will explain why. One of the many antiquated things in Archicad.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Thanks Brett. That did it!
