Inclined wall?
Hi guys, I'm pretty new to this program and I'm having a problem with inclined/sloped walls.
The concrete wall is already a bit inclined and I need the top part of it to be cut off just like the inclination of the black wall.
Is there a way to edit the wall not using morph / SEO?
A wall can incline at an angle - i.e it does not have to be vertical.
However it can not slope from end to end - i.e. one end lower than the other.
To do that you must trim (connect) it to a roof or shell, or perform a Solid Element Operation t cut away the part you do not need.
Hope they had an easier way to edit walls... I'll use the SEO to cut it then. Thanks Barry!
