Increase Shell tool cruve setting ??
Hi
I need more segment along my profiles in ruled shell !!!
I was modeling a small detail when I faced the lack of segment and I couldn't find any solution to increase the segments.
thanks
hamed kassaei
See if the registry tip from Barry in this thread helps. That was related to revolved shells - so don't know if it will affect ruled ones.
http://archicad-talk.graphisoft.com/viewtopic.php?t=38490
If it does not improved the ruled shell appearance, perhaps the magic wand settings for creating the initial and target profiles will help. See the link from the above thread.
Karl
THANKS ALOOOOT
it was really helpful ...there was a option in my registry which relates to revolved and ruled shell , as "Barry Kelly" said on the post.
I wish these setting will be available in archicad 16 not in registry because if you change your computer ... the setting will be back to default setting !
BTW, magic wand setting doesn't have any affect on shells.
anyway thanks
hamed kassaei
