Increase all the nodes of in my mesh by a factor 10
Hi all
I have made a schoolboy error and created a terrain that is out by a factor of 10!
Is ther a way of globally correcting each mesh tool node without changing each individual one?
Your help is much appreciated!
7 Replies 7
Use the Resize command.
It is somewhere in the Edit menu.
Thanks, for that. However it just resizes the terrain and not the heights of the nodes.
Do you have any other suggestions?
I think you will have to modify the heights one by one.
David Maudlin
novice:
You could try saving the mesh as an Object (use the Top View in the 3D Window), and then adjusting the height of the object, which should rescale the object's height proportionally. The downside is that it will no longer be an editable Mesh, but a mostly fixed object.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
elevate?
thanks for the help guys....
thanks for your help guys
